Your just confusing me now! So are currently opting for Mobil 1 V-Twin 20W-50 because 20W will be thicker in winter, 50 because it will remain thicker at higher temp and ZDDP higher because it will lessen the wear on flat tappets?
Mobil V-Twin is apparently not available in the UK so that's just incidental info from someone else.
The No. 1 thing
seems to be that these older engines need high levels of ZDDP. It seems that legislation prevents the manufacturers from putting more than 1000ppm of the stuff into engine oil intended for road use in passenger cars. So they put in amounts much less than 1000 and use different additives which make the oil more slippery. Even some of the "Classic" oils have ZDDP at these low levels and some claim that there is no longer a need for so much ZDDP since part of their purpose was to soak up lead compounds from petrol residues.
Motorcycle oil, being exempt from the legislation governing cars, is allowed to have high levels of ZDDP. It also tends not to have slippery additives because these mess up the clutch. As many motorcycle engines are air-cooled and tend to run hot in the same way as a Fiat 500 or 126, the viscosity ranges tend to be similar to those originally recommended by Fiat in moderate climates such as Scotland.
The first of the two numbers in the multigrade oil rating is its notional viscosity at (lets call it) colder temperatures such as when first starting. So the lower this figure, the more easily the engine will turn and the more quickly oil-flow will get where it is needed. The second figure is the effective viscosity of the oil at very high temperature and the higher that number, the thicker it will be.
So the "art" in this is to get a "Goldilocks" range which will neither be too thick nor too thin at both ends of the range. Fiat suggest 15W40 for my engine; many people use 20W50; technically too thick at startup and too thick at speed. 10W60 is technically too thin at startup and far too thick at speed because the viscosity increases are not in simple steps....60 is apparently pretty thick!
I haven't even started on the debate about synthetics...but as these are more stable at high temperature I have a leaning towards using them.
So I'm looking at Mobil 1 15W40/50 because it's synthetic, has a lot of ZDDP in comparison with most oils, is thinnish in winter and thickish in summer.
Phew!!!
