General 1966 disc brake upgrade
Tin Tin
Member
London
TinTin,
My car has 8" discs from a Cinquecento/Sciento - you may need to mod the caliper to fit your wheels. Check on the other forums for parts and the mod.
Ian.
I bought my five speed conversion through the seller mentioned and it arrived damaged - he was very difficult to deal with until I took official Ebay action - which is complicated because it was a purchase through the Italian Ebay site - required phone call to Ebay......
I have built up my front disc assembly (to be fitted as an 'over the winter' job) by purchasing some Cinquecento callipers, a pair of adapter plates and new discs. If you are sticking with original pattern (190pcd) wheels, Axel Gerstle does a good kit that only increases the front track by about 2mm, which means that you don't have to modify wheel arches. I have found his company very easy to deal with--never had a problem with them--go onto their 'tuning' section, then 'brakes'.
Hi TH
Axel does sell some seriously good kit but even with today's Rate of exchange it's still Gbp500 +. No doubt worth it but i am trying to find a cheaper solution. I do not mind the looks but they need to be fit for purpose.
I will be using the original wheels which I believe means they are 190pcd size.
Is the set up your creating for original wheels as well and will the track be increased?
Peter
and here is my set fitted.....£300
most sets require the spacers to return to the original wheel offset
Andrew / Steve
Thanks for the extra inf and pictures. Was any body work modifications required or did they fit with the standard wheel arches?
Either of these seem to be the way to go assuming no mods required.
Peter
Andrew / Steve
Peter
It was fine with mine with lower suspension standard steel wheels but wider 145/70 tyres. On the wider alloys, and even wider 165/60 tyres, the RHS needed a little fettling on the inner front seam.
cheers, Steve
Steve, I am running standard wheels and tyres so sounds like they will be ok too.
Peter
