Pete145
Member
- Jun 2, 2014
- 288
- 85
Hi everyone,
This is a sub-thread to my fuel leak thread a couple of days ago, but worthy of a new discussion I think.
The leak I referred to is coming from the carburettor, specifically during the engine upgrade that car had a larger car fitted, and upgrade to a Weber 28 (because of the engine tweaks) which has a fuel return line.
They have blanked off the return line using a 4" length of fuel hose, a jubilee clip to attach to the carb, and an M6/M8 bolt jubilee clipped to the end.
Fuel is dripping out of that length of hose at quite a rate, and I could simply tighten the jubilee clips (which I'll do in the short term) but I'm sure it will just happen again, so I'm looking for a more permanent fix.
A couple of other options have been suggested:
1 - Adding a T-section into the fuel in line, just before the fuel pump, and re-routing the return pipe back into the fuel line.
2 - Removing the hose that's being used as a block, wiggle out the brass piping that extrudes from the carb, and plug that with a bolt and JB Autoweld.
Any views in this? Has anyone used either of these fixes and have a procedure to follow?
