.....and that 180 miles wasn't without its dramas. It's not always plain-sailing with Murf.
On a few occasions recently there have been moments when it has seemed that the car has momentarily run short of petrol. The circumstances have been when I'm at sustained speed, especially on undulating roads. I had investigated float levels and confirmed a good supply of fuel from the pump. Things had settled, but today I had a couple of times where the engine was hard to start after a short stop....classic fuel vaporisation. It wasn't a cold winter day, but it didn't seem warm enough to cause that sort of issue. After one short stop, and having got going again, the engine gave up halfway across the very long, Dornoch Bridge on the A9. This forced us onto a very narrow strip at the side, whilst lorries hurtled past at top speed.
It was going dark and threatening rain. I investigated and found a good spark, but with obviously overheated plugs. The mixture screw was out by two full turns; I randomly turned it to one and a half. As it's easy to get at, I also removed the idle jet and blew though it. The split at the end, which keeps it wedged in place, was flattened and needed opening out. With everything back in place it started first time.
I restricted the car to around 50mph for the rest of the 60 miles home, which was wise for the other reason, which was that by then, I was driving in rush-hour traffic in torrential rain.
More investigation is needed because I had another jittery moment only a few hundered metres from home. I may put the 123 back to its standard setting just in case I'm pushing the engine a bit hard. The main thing is, we got back in one piece, as usual.
