I've been thinking about 'why is there a spacer fitted'?
There isn't one on the front hubs - taper roller bearings, adjust nut to set bearings, lock in place, job done.
The only conclusion I can reach is that it's to clamp the splined coupling firmly to the axle shaft (via the inner bearing, spacer,outer bearing), while still limiting the bearing preload to the correct figure. Without the spacer fitted, the coupling would only be held in place by it's splines, which would wear due to rocking back and forth as the car went from acceleration to deceleration and eventually result in failure.
Similar situation on rear drive axles with a collapsible spacer fitted between the pinion shaft taper-roller bearings, I reckon it's to clamp the driveshaft flange firmly in place while controlling the bearing pre-load and not rely just on the splines to prevent movement between the flange and shaft.
On the other hand there's other situations on cars where something is driven by splines/serrations where the two parts are not clamped firmly together e.g. front wheel drive cv joints to drive shafts.....
Any Powertrain? Engineers care to comment?
AL.
