AndrewHarvey
Established member
- Jan 17, 2015
- 1,471
- 290
Mr Fiat do new carbs of both 26 & 28 mm size
Change of subject. Would a 126 carb be better than the standard 500 l carb if nothing else is changed on the engine? That is to say would I get any noticeable gain in power? I am asking because my mechanic just rebuilt my engine while I was gone on deployment. He brought everything back to original to include the carb. I have the 126 carb and was wondering if it would be worth refitting.
Chris,
When you replaced the starter/choke cover, did you use a gasket between it and the main carb body? If you did, which did you use? The rebuild kit doesn't seem to be supplied with a gasket specifically for this.
Thanks,
Matt
I have stripped down , I would guess over 50 26 & 28 IMB carbs and had never seen a gasket on the fuel enrichment assembly then last year while refurbishing some used 26 IMB carbs I came across one that had a gasket in that joint. Never seen one in a rebuild kit or shown on a parts list so something of a mystery.
I also have never seen an official CFM figure for the Weber IMB carb, but if you are good at maths and want to work it out, look on the site:---'Stovebolt Forums'---'CFM Rating re-loaded'. The CI displacement of a 500 (110) engine is 30.5---max torque is at 3,500rpm and max power at 4,400rpm. The 110 engine peaks at about 4,500rpm. If you ARE able to work out the CFM of the IMB carb, please let us know, it will be another little piece in the information jigsaw!
Will do....
I suspect it’ll require the use of a “flow bench” to get a number of any accuracy. Will keep you posted.
