You may not need to do much with these brakes as from memory they are self adjusting. Apart from gently pumping them a couple of times to centre the shoes and making sure that the self adjuster is sitting properly on it's peg mount, they should work well from the outset. All new shoes take a little time to 'bed in' but if they rub or bind excessively, the bonded friction lining may be too thick. In that case you will need to fit shoes with a thinner lining. I think that someone on this list had that problem not long ago. The other problem that may also cause binding is eccentric or warped drums. These should be skimmed or replaced.
Some drum brakes have a snail cam that is used to adjust the shoe/drum distance so it lies within the tolerance dictated by the manufacturer. These drums are not self adjusting and need periodic readjustment to maintain braking efficiency as the lining wears.
And finally, like disc brakes, the friction surface must be kept clean and free of grease/oil for the brakes to work properly.
Whilst drum brakes are not as efficient overall as disc brakes, with simple maintenance they perform more than adequately. Checking the wheel cylinders for hydraulic fluid leaks, linings for wear, drums for eccentricity and regularly changing the brake fluid will go a long way to ensuring a trouble free, safe braking experience.
Chris
