![]() | #1 | ||
Posts: 169 Thanks: 2 Trader Rating: 0 ![]() | Mixture Screw Where to get a proper mixture screw for 500F? http://www.fiat500ricambi.com/fiat50...+system/BV1043 http://www.fiat500ricambi.com/fiat50...+system/BV1044 Tried this two ones but they are not same as my old one, I think the old one is abit longer? Where to get the right one.
![]() | #2 | ||
Posts: 169 Thanks: 2 Trader Rating: 0 ![]() | Re: Mixture Screw This is the srew for 26IMB. Quite difficult to find anywhere.. My problem is that the sharp end of the screw is worn...
![]() | #3 |
Posts: 452 Thanks: 23 Trader Rating: 0 ![]() | Re: Mixture Screw If the sharp end of the screw is worn, the carburetor body may also be damaged. You might want to see if you can buy a used one on ebay and rebuild it. John
__________________ John 1969 Fiat 500L |
![]() | #4 |
Posts: 74 Thanks: 0 Trader Rating: 0 ![]() | Re: Mixture Screw This looks like the kit you need: http://webshop.fiat500126.com/index...._imb_4-5c.html Best regards Ian
__________________ ![]() |
![]() | #5 |
Posts: 452 Thanks: 23 Trader Rating: 0 ![]() | Re: Mixture Screw Just to make my point one more time. If the mixture screw is damaged, the carburetor body is most likely also damaged. A replacement mixture screw will still not work well with a damaged carburetor body. It is almost impossible to damage a mixture screw unless it has been screwed in too tightly, which will damage the carburetor body also. If you damaged the mixture screw after you removed it, then a replacement screw would work. The kit listed in the previous post is expensive. You are better off getting a used rebuildable carburetor and buying the cheap rebuild kit that comes with just the gaskets and orings. John
![]() | #6 |
Posts: 1,497 Thanks: 105 Trader Rating: 0 ![]() | Re: Mixture Screw John is correct. If the tapered end of the mixture screw is damaged then more likely than not, the seat is also damaged and a new screw will not solve your problems. Having said that, the metal in the mixture screw may be softer than that of the carby body, so the seat could be OK. I'll try to find out for you. Any chance of you posting a photo of your old screw? Good second hand carbies are available, though obviously you'll have to make sure that the same problem doesn't exist in whatever you buy. Chris
__________________ 1967 Fiat 500F (Enzino) Sundry other Italian rotboxes ![]() Amante di vecchie automobili italiane |
![]() | #7 | ||
Posts: 169 Thanks: 2 Trader Rating: 0 ![]() | Re: Mixture Screw Hi, Ill post a picture later this week.
![]() | #8 | ||
Posts: 169 Thanks: 2 Trader Rating: 0 ![]() | Re: Mixture Screw Forgot to take a photo from the screw. I mailed fiat500vdlaan about the co-screw for imb 26. Got an aswer that these one is not produced anymore, so that is the reason why they are hard to find.
![]() | #9 |
Posts: 452 Thanks: 23 Trader Rating: 0 ![]() | Re: Mixture Screw This looks like it on ebay. You might try to match up the weber part numbers, or just take a chance since it is cheap. http://www.ebay.com/itm/WEBER-ADF-ID...f949b0&vxp=mtr John
![]() | #10 |
Posts: 452 Thanks: 23 Trader Rating: 0 ![]() | Re: Mixture Screw You can get a new original 26imb-10 carb here. http://www.dellorto.co.uk/merchandis...rtsectionID=52 John
![]() | paulo arrigoni | Panda (Classic) | 6 | 11-02-2010 21:09 |
![]() | Peterg | Uno | 8 | 25-09-2005 21:12 |
![]() | smokeme | Panda (Classic) | 5 | 10-04-2005 19:25 |
![]() | pags | Cinquecento / Seicento | 7 | 14-03-2005 22:12 |
![]() | kevin_ross100 | Panda (Classic) | 2 | 23-12-2004 10:02 |
