I've started sketching out some ideas for the instrument panel. I've gone all 'arts and crafts' and made a cardboard template, with the pictures of the actual gauges glued on. Before I start fabricating anything, I wanted to check it would fit in place and wouldn't get in the way of my knees.
It's a bit amateurish at the moment, but it gives me an idea of how it will fit together. I'm tempted to have a border running around the panel face which will project out slightly from the face. I'll have the border covered in the same foam and vinyl that was used on the knee pads. The reason for this is both to finish it off, as well as pad it slightly in case I whack my knee on it.
As well as the gauges, I plan on adding a couple of buttons/lights. I'd like to modify (by I, I mean Dad) the wiring to build in a hazard unit, so the panel would have a hazard switch and amber light on it. We're also (by we, I mean Dad!) going to add an intermittent wiper function, as well as an electric pump for the washer bottle, so buttons/switches for this will also be built into the panel.
The idea is that I'll create two brackets at the top of the panel which will bolt into the forward-locating holes for the glove tray. I'll create two struts towards the bottom of the panel which will be positioned diagonally upwards to bolt into the rear-locating holdes for the glove tray. The idea being the struts will make the panel more rigid and stop it flexing back and forth when pressing buttons on the panel.
From left to right the gauges are: oil temperature, oil pressure, tachometer, clock/volt meter, fuel gauge.
Matt
