Old 24-10-2011   #1
USA
Reuse or new big end rod bearings?
Hey guys,
Got the pistons back into the cylinder after doing a rehone. The head has been cleaned up and ready to go. But how do the condition of these big end connecting rod bearings look? I don't know how old they are.
What do you guys think before I order something that is still good.
Thanks,
Frank
usafstud is offline Reply With Quote Quote
Old 25-10-2011   #2
Used to be somebody...
oopsadaisy's Avatar
oopsadaisy has donated!
Re: Reuse or new big end rod bearings?
They look pretty badly scored to me.
I would replace them as a minimum.
What's the crank shaft like?
oopsadaisy is offline Reply With Quote Quote
Old 25-10-2011   #3
USA
Quote Originally Posted by oopsadaisy View Post
I didn't really get a chance to inspect the crankshaft. What do you guys think of the quality of parts from Mr.Fiat
Old 25-10-2011   #4
Shed Troglodyte
Bambino's Avatar
Bambino has donated!
Australia
I must admit that having gone this far, I'd be replacing them. You will need to get the bearing surfaces on the crank measured as well to see if they are worn.
Parts from Mr Fiat are OK.
Chris
1967 Fiat 500F (Enzino)
Sundry other Italian rotboxes
Amante di vecchie automobili italiane
Bambino is offline Reply With Quote Quote
Old 26-10-2011   #5
USA
Quote Originally Posted by Bambino View Post
Chris
What should I be measuring for? Taper, out of round, and what else? I plan to get new rod bearings and do plasticguage to measure the clearance between crank and bearing.
Here are some pictures of the crank in the engine.
Old 26-10-2011   #6
Shed Troglodyte
Bambino's Avatar
Australia
Mainly out of round because as the engine is fundamentally unbalanced the crank bearing surfaces will wear eccentrically.
I took mine to the local Engineering works and they ran the electronic calipers over it. As it was within tolerance, I just replaced the main and big end bearings.
Chris
Old 26-10-2011   #7
Australia
I would have said 'eccentrically' but I neither know how to spell it or know what it means!
There are some very clever and helpful people here.
Joe R
tjmra is offline Reply With Quote Quote
Old 26-10-2011   #8
Shed Troglodyte
Bambino's Avatar
Australia
Quote Originally Posted by tjmra View Post
Take a look at my avatar and you'll get the picture
Chris
(Tu) main and rod bearings dbith57 X1/9 1 19-09-2012 10:18
(T) Fiat Punto MK2 Rack End or Tie Rod End 3395 Punto (Mk2/2b) 10 10-08-2011 23:06
(T) big end bearings 16v mt-tuning Tipo (Classic) 0 26-10-2009 11:32
(T) jtd big end bearings deezel57 Bravo / Brava 2 30-07-2009 23:27
(T) BIG END Bearings - Easily repairable??! What are they?? please take a look dbriglee Punto (Mk2/2b) 19 16-03-2006 22:51
