Hi all,
Wife complaining (unusual!) today re her car having no power.
Tried it and found that it appeared to be firing on one cylinder!.....removed plugs and both very sooty. cleaned and refitted and engine ran fine.
Thought i would look at carb, found slow running jet partially blocked so cleaned and refitted, adjusted idle speed (Generator light just flickering as per Haynes) BUT when trying to adjust mixture screw, no difference all the way in or out! removed screw, needle has a flat end, is this correct? should it not be a sharp point (it does taper down at the end but has a distinct flat face) as with other carbs i have messed with?
Any help appreciated.
Regards, Graham
Regards, Graham
