jjacob
Member
It's not the large stuff that stops a carburetor. It's the small stuff. Jets are very small. It does not take much to plug one up. Air and gas need to be clean.
You need to also remember that small grit ends up in the engine and will wear away the cylinder walls and rings. You need a proper air filter on any engine.
That's not to say you can't use the trumpet. It needs a proper filtering media on it. I would say that there is not much surface area though with the trumpet.
Those who are using the FZD (Chris) can weigh in on what they are using for a filter.
John
John
