Hi Levi,
You probably won't believe this, but I actually had composed a very much longer post than my above one (post
#9 ) and had included checking out the ignition switch, the terminal markings on the back of it, which colour wires went to each terminal and what each wire was connected to, on the car. But I edited the post so as not to overwhelm you with too much information or things to check out.
I have heard of ignition switches 'having' to be replaced. These switches rarely gave trouble, but the wires connected to the rear of the switch can become loose/detached, especially if someone is working on something nearby and pushes against them.
My approach is always to check out a suspected faulty component
before replacing it. In the above situation (ignition switch), I've often found the problem is actually a loose connection, not a faulty switch. Of course, anyone fitting the new switch will ensure that all wires are connected securely - problem now solved but was it a faulty switch or just a loose connection?
On occasions I've opened up the switch to examine the contacts. It can be opened easily, just prise out the wire clip on the rear of the switch. Often just a clean up, maybe a slight stretching of any springs fitted, reassemble and you're good to go. Incidentally, if you remove the switch part from the ignition switch unit, inside on the switch operating shaft, you might iirc, find a metal disc onto which is stamped a number, this is the key number for the ignition switch.
On some U.S. forums dealing with the 124 Spider, I've seen mention of people 'having' to replace the ignition switch. Apparently, some of these replacement switches have a slightly different number of terminals to the original fitment, which can cause some confusion, some say they are for the Lada cars. There's a big difference in price between one of the cheaper switches c. $80 versus a genuine Sipea switch @ c. $499? But I don't believe the cheaper switch is substandard in any way and I certainly wouldn't fork out $500 for a switch.
I'd suggest you check out the security of all wires on the rear of your ignition switch before replacing it. To do this,
1st, disconnect the negative (-ve) terminal on the battery. There is a soft plastic cover/shroud over the bunch of cables connected to the ignition switch. Hold the bunch of wires and ease the cover away to expose the wires, if you just pull the cover back, you'll likely disconnect one or more wires. You might need a mirror to see what you're doing. Check all wires are securely connected - if any are loose, remove them and squeeze the sides of the terminal slightly using a pliers and refit them.
Pay particular attention to the small blue with black wire going to terminal 15 - this is the live feed to the ignition coil. Also the heavy black wire going to terminal 30/1 - this is a live feed from the battery. The heavy red wire going to terminal 50 operates the starter motor. The heavy brown wire going to terminal 30 also feeds power to the ignition switch. These are the important wires as regards ignition and starter motor operation. These heavy wires and the blue with black wire are not fused, hence the warning to disconnect the battery lead before working on them - safety first!
If you decide to remove the ignition switch to work on it on the bench or to replace it - some of these cars have block connectors a short distance from the switch that can be disconnected leaving the wires still attached to the switch rear, if not the wires will have to removed - make a not of which colour wire goes to which terminal (the terminal no's are on the switch block).To remove the switch from the steering column, insert the key, turn to the 'Mar' position (i.e.'ignition on' position), locate and remove 2 or 3? Phillips head screws on the periphery of the switch, then wiggle the switch out.
Thermostat :-
Afaik, Autoricambi are just as good as Midwest-Bayless, similar pricing but Autoricambi do seem to specialize in the 124 Spider... Consider they may be getting their replacement parts from the same sources....
If the thermostat wasn't leaking, why not just re-use the rubber sealing ring? I've seen 2 types of rubber sealing ring, one is square-section rubber, the other is actually a 'U' section, this latter type needs to be stretched over circumference of the thermostat. I'm not sure if there is a paper gasket also used on your thermostat water outlet (it's different from the one I was describing as being in 2 parts). If there was no paper gasket there, there probably isn't one needed - Autoricambi lists a paper gasket (Sku GA1 - 401 @ $7.99) but it's out of stock. Autoricambi also list a thermostat (CO9 - 413) which opens at 180F. Midwest-Bayless list a thermostat but it opens at 160F, same as the one you have - however they say that this lower than stock opening temperature helps to improve cooling.
The thermostat you've fitted will probably be fine to use. I can't see in your pics if it has either a small hole or a hole with a 'jiggle pin' in the metal disc - either of these help to avoid air locks, assist with 'burping' the cooling system.
If neither is incorporated in your thermostat, I think I'd drill a small hole in the flat part of the metal disc of the thermostat away from the central working part - 3mm (1/8inch) would probably work just fine.
I'm afraid I can't advise on what size of bolts would replace the air injection? pipes in the cylinder head - this emission equipment wasn't used over here.
It's hard to judge from your pics but if I was to hazard a guess, I'd say 10mm. As Fiat generally use ISO-Metric fine threads, I'd be looking for 10x 1.25mm. The alternator adjusting bracket bolt is 10x1.25mm, you could maybe try removing one of the air injector pipes and try this bolt in the hole. If the thread is finer and tapered and approx. 10mm, it could be 1/8 inch BSP thread, a plumbing supplies stockist might have suitable plugs in stock.
However, see:-
https://autoricambi.us/cylinder-head-air-injection-plug-set
(SKU: CHO-024 @ $26.99.) for a quick but pricey fix.
In summary, I'd drill a small hole in your new thermostat (it should work just fine) if there isn't one there already. Refit the thermostat using the original rubber sealing ring. Fabricate a paper gasket if there was one fitted originally, otherwise leave it out.
I'd check out the security of the wires at the rear of the ignition switch most carefully before buying a new switch. Even then, I'd try opening up the existing switch to check it out and try to fix it before ordering a new switch.
I'd remove one of the air pump pipes from the cylinder head and try to match it up with something standard. Are there any fastener (bolts, nuts etc.) or plumbing supplies stockist near to you - bring one of the air pipe fittings in, they should be able to match it up with a standard bolt/blanking plug.
Thanks for the 'thanks', always appreciated
Al.
