ericsky
I can't find where these 3 male plugs connect in the harness behind the center console. It's a newly acquired '79. The ignition key broke off and disappeared so I removed the instrument cluster to replace the ignition switch and only remember disconnecting harness plugs on the left side behind the cluster. After replacing ignition and locating the cluster the radio quit so I removed the center console to find the fuse holder and replaced the fuse. I don't remember disconnecting either of the 3 plugs pictured. As shown, the left one has 6 terminal cavities and all are occupied. The middle one (white) has 8 terminal cavities with 6 occupied and the right orange one has 8 with 6 occupied. Each plug has one hot terminal.
I picked this up over a year ago and am fairly sure all lights worked when I drove home. Now I can only get current to the driving lights in the rear tail assemblies, no brake, reverse or turn signal that I can notice. Headlights and all 4 marker lights work. I did a needed improvement on the rear light ground. I imagine it's possible there'd be 1 or maybe 2 plugs unused but not 3. And typically the harnesses are short enough to barely reach so it's not difficult to find the plug's mate. I've looked for the female plugs under/behind the dash and console with no luck. I also can't find where the bulb socket would plug into but there appears to be no current. Please take a look at the pic and help if you can. Thanks!
