FIAT Auto Specialist Team
Thread Tools
Old 28-01-2019   #1
USA
ignition coil help
I have a 79 spider 2000. needing help with coil. Can not get good results testing it. Problem is on the coil it says " use with external resistor". Where would the resistor be?
The number on the coil is D-511/512 12 volt. Is this the correct coil?
myturn is offline Reply With Quote Quote
Old 26-05-2019   #2
Canada
Re: ignition coil help
On the 1979 200 you should have a electronic distributor, on those there is no resistor also the coil should be made for the electronic distributor.
After a quick search the D511/512 coil is a GM 80's coil, i do not now much about them, you should search if it is for a points distributor or it might need a external resistor.
I would dump that coil and use a Marrelli or Bosh blue coil.
alainm is offline Reply With Quote Quote
Thread Tools
(T) ignition coil, fiatbakk Doblo 1 18-03-2016 01:20
(T) ignition coil 124spiderman 500 (Classic) 1 10-05-2015 00:22
(G) Ignition Coil johnnyboyo Stilo 3 09-12-2013 21:35
(T) Ignition Control Box issue? Ignition Coil? mtblan0 X1/9 4 21-07-2010 22:49
(T) Need new ignition coil/s imola_fowkes Cinquecento / Seicento 24 29-03-2005 02:01
