Hi, I'm Charlie in Texas.
I recently bought an 82 Spider 2000 in pretty decent shape. Drives surprisingly well... at least... it did.
The other day, something bad back aft occurred... and I thought Oh crap what was that?? Then I realized the back of the car started rockin. Well THAT was no bueno! Pulled over and had a look... found some cheesy thin-walled bar had broke... some sort of stabilizer. Towed it home.
Spent a short while skimming the web to find it's called a panhard rod. Okay... that's an odd name for a stabilizer. Why not just call it a rear stabilizer? Anyway, found there are two types... the older and the newer. Being an 82 model, I needed the newer.
It arrived today and I went to pull out the old one. That's when I noticed it was different... not just the shape, but the length as well! Apparently, my car being an 82 should have the shorter version with the bend in it. But, the one that was in there was the longer, straight version. So back to the web and order the other.
It's not that big a deal... just that I will have to wait a few more days to get the other rod (I was really excited thinking I was going to have the car fixed today).
Then I got to thinking... so what's different under my car that makes it need the older version rod? If something major is different, will I run into other things later that might not fit because someone modified something with parts from an older car?
Another thing that surprised me was how that rod doesn't really have a lot of meat to it. The water pipes in my house are thicker than that rod!
Thoughts?
Thoughts?
