I have 68 850 sport spider with the 903 cc engine. I bought a new oil sending unit, which is the two piece unit with the oil light sending unit that is inserted into the oil gauge sending unit and threaded into the block. The unit came with two new copper crush washers, and it leaks bad. The photo is of the old unit, just so you can see what I am talking about. Installed, going from the block outward, there is a crush washer, then the oil gauge unit, then a crush washer, then the oil light sending unit. The leak is from the outer washer between the two units. I installed it with the new washer, and then I tried it with the old washer. Same result. Any thoughts on making it stop? Thanks!
