Hey folks, so I'm working on the master cylinder for a '69 124 and I'm a little confused. There's a pair of rubber hoses that run from the master cylinder reservoir to the master cylinder itself, on the one hand, where can I even find rubber brake hoses without fittings on the ends, and on the other, how am I going to find hoses with a 1/4 inch opening on the one side and a 1-inch opening on the other? the old hoses have completely perished with age, is there a simple solution to this problem? any insight you can give would be helpful.
