im Axle Specialists
Thread Tools
Old 04-11-2015   #1
USA
Clutch Return
My clutch operates fine but it only returns half way. Is there an adjustment to be made?
axaaddict is offline Reply With Quote Quote
Old 05-11-2015   #2
Ireland
Re: Clutch Return
There's an adjuster on the end of the clutch cable down at the gearbox,
so you'll need to get underneath.
Try lifting the clutch pedal, normally it sits level with the brake pedal.
Adjust the adjuster until you have approx 3/4 to 1 inch of free play at the pedal, i.e. before the clutch starts to be disengaged.
This free play is measured from the clutch pedal being level with the brake pedal to where you feel it encountering pressure, i.e. starting to disengage the clutch.
Alternatively, at the adjuster end you need about 1/8 - 3/16 inch free play on the cable before the clutch starts to be disengaged.
Don't go too tight on the adjustment or the clutch will slip (revs increasing without an equivalent increase in speed, when you accelerate in a gear, especially 4th or 5th). Alternatively, too loose on the adjuster will typically cause crunching when engaging reverse gear.
AL.
F123C is offline Reply With Quote Quote
Thread Tools
(T) Clutch Master Cylinder Return Spring Pull9Gs X1/9 7 02-03-2018 22:57
(T) Grande Punto Clutch Pedal Wont Return surfamakikomi Grande Punto 12 21-01-2014 14:17
