Here are a few gems from distant memory. They may help.
A mini with similar issues, cut out on bends. Coil is mounted horizontally. Turned it around to face the other way, then it cut out on bends the opposite way. The oil-filled coil had leaked and when what was left surged inside, it cut out.
Carb float level too low, fuel surge let some air through causing weak mixture.
Rover SD1 2300 & 2600 would misfire after using screenwash. Leaking pipe to jets mounted on bonnet would drip onto coil.
I assume you've checked the obvious, plugs, points, condenser, leads, fuel pump, etc., so time to look for the more bizarre.
Is there a radio suppressor on the distributor or coil? Disconnect it and try again.
Most distributors have a small cable on the baseplate for an earth. They can break inside the insulation.
Are the engine mountings good. Engine movement has sometimes caused connections to break or disconnect, temporarily or permanently.
Hope something helps, or triggers other ideas. Good luck.
