paintdudeluke
- Dec 12, 2013
- 23
- 8
Without going through the entire process I've already tested here, this is where I'm stuck. The end of the diagnostic process concluded that the ECU needed replaced. I just put in the new ECU. Exact same problem. The 4 injectors are not firing. Now that I've proceeded to assess the situation I discovered 2 facts that I am not sure what they are telling me. 1) there is no power being conducted THROUGH the injector wires. 2) Both wires to each injector are HOT. Is this a relay issue?
Thoughts, Normally .....
a) they all remain hot awaiting a ground signal to complete the loop?
b) they need energized by the ecu and flow to ground?
How can they both be hot with the key in "run" position?
