![]() | #1 | ||
Posts: 4 Thanks: 0 Trader Rating: 0 ![]() | Thermostat replacement instructions?? I see the thermostat housing (attached photo) at the end of the top radiator hose. Before I take it apart, my past experience with other cars has been that the themrostat sits inside the housing and is a simple take out old/put in new process but I can't yet see nuts to take apart the housing. When I detach from the hose clamps will this become evident or am I to replace the entire housing?? I am assuming there will be some coolant loss when removing from the hoses......do I just add replacement coolant after reassembling or does the system require flushing? Thank you
![]() | #2 |
Posts: 13,980 Thanks: 1490 Trader Rating: 5 ![]() | Re: Thermostat replacement instructions?? Hi, Welcome to the FF. Most Fiat thermostats are supplied as the complete housing. Which Spider/engine do you have?
__________________ Stilo Parts For Sale: Connect Nav+ Map Discs - Wiper Motor (NEW) - JTD/JTDM Front Brake Discs (NEW) - 5 of 215/45-17 Alloy Wheels For details, click here: http://www.fiatforum.com/classifieds...0&ppuser=48514 |
![]() | #3 | ||
Posts: 4 Thanks: 0 Trader Rating: 0 ![]() | Re: Thermostat replacement instructions?? Thanks for the welcome. Just trying to figure out how to navigate the site. I have a '81 2000 Pininfarina Spider.....was originally a Turbo but the turbo was removed when the engine was completely rebuilt a few years ago. That is fine as far as I am concerned.....seems they were always the source of issues.
![]() | #4 | ||
Posts: 4 Thanks: 0 Trader Rating: 0 ![]() | Re: Thermostat replacement instructions?? And thanks for the tip about the thermostat/housing. It did seem a bit different than what I have seen before (mostly British) in that there didn't appear to be a way to lift off the top of the housing to get to the actual thermostat and I didn't want to start taking it apart until I knew I would put it back together (finished) in the same session.
![]() | #5 |
Posts: 13,980 Thanks: 1490 Trader Rating: 5 ![]() | Re: Thermostat replacement instructions?? Here's a few pages from the cooling system section of the Spider workshop manual. The thermostat is item #6 on page 10-161. There's also bleeding information on page 10-160. You'll need to do this after refilling the cooling system. .
Stilo thermostat replacement | spurds | Newbie Central | 1 | 09-02-2013 20:51 |
![]() | Skyperr | Grande Punto | 4 | 04-12-2012 17:20 |
![]() | patch201 | Doblo | 2 | 20-12-2009 14:10 |
![]() | swifty100 | Tipo (Classic) | 4 | 27-08-2009 20:22 |
![]() | swifty100 | Tipo (Classic) | 0 | 24-08-2009 21:04 |
