Old 12-08-2012   #1
USA
Need help 79 ignition switch
Through a process of elimination I'm replacing the ignition switch on out 79 2000. I bought a new correct switch and have the old one partially removed but it's being very stubborn. I have removed both the set screws and depressed the outside lock through the hole but still seems to be catching. Looking at the new switch it seems you would have to turn the key to the start position to get the steering lock to retract as much as possible. I'm sure I'm missing something simple here. Anyone done this before and can offer any tips?
792000 is offline Reply With Quote Quote
Old 12-08-2012   #2
USA
Re: Need help 79 ignition switch
Never mind, figured it out. For those in the same predicament you depress the side stop first then insert key and turn, I had the key in already. Don't know why it worked but it did, on the road again.
(T) Ignition Switch Bernied 124 Spider (Classic) 1 08-09-2008 00:39
(G) ignition switch DRUE1 Punto (Mk2/2b) 5 21-12-2007 17:40
(T) How do you take out the Ignition Switch?? kass729 X1/9 3 28-08-2007 09:27
(T) ignition switch mrstadds Cinquecento / Seicento 0 29-11-2006 13:40
fiat punto ignition/steering lock and ignition switch ste21000 Auction Watch 7 20-03-2006 01:23
