Hi new to the forum.
Can any forum member assist with rear inner/outer bearing width information - 850 spider [1971]
New bearings installed however with original spacer inserted the brake drum will not completely cover linings - short by about 5mm. I don't want to machine spacer.
If the inner bearing cap is tightened - the stub axle is pushed out of the outer bearing by about 5mm leaving the drum to backing plate space. ?
Cheers Chris.
Cheers Chris.
