General Uno dizzy in X1/9?....
Martinp
manchester, United Kingdom.
Hi all!,
I read somewhere that a Fiat Uno dizzy with electronic ign would fit a (points)X19, you would also need the coil, nessesary wiring and a vacuum connection for the vac adv. Apparently the X19 dizzy cap fits the Uno dizzy? Can anyone confirm this and post any details of conversion, as i would like do away with the points and condenser setup badly! Plus my dizzy's a bit worn anyway.
THANX.
The expression " Dizzy " is indeed a slang term meaning a distributor.
I am not fully familiar with the X19 but understand that this conversion is well known amongst X19 owners. I am told however, that although the Uno electronic distributor assy is a simple swap with the original, there needs to be a " dent " made or a hole cut, in the bulkhead to clear the distributor cap.
Hope this helps.
Pete.
<blockquote id="quote"> face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by Martinp
A dizzy is a british shortened word for a distributer![:eek:)]:)
You're kidding right!!;)
<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
I am sorry for my "il incompetente" english. I have problems enough with the norwegian engine words, so a british slang is even more difficult than straigh forward english. I usually look up the english frases, but "dizzy"...
Hehe, I seriosly thought i was a model version, or that your car was dizzying from side to side when you turned left and right when driving. Which my Uno did before I changed springs.
So - no I wasn´t kidding.:D
Morten.
