Old 08-12-2009   #1
USA
Repositioning distributor
Is it possible to reposition the distributor on a '78 124? I have noticed that the plug wires coming out of the distributor point towards the firewall and I believe that the wires are getting in the way of closing the hood easily.
rasouth is offline Reply With Quote Quote
Old 08-12-2009   #2
USA
Re: Repositioning distributor
stock location shown:
so, the answer to your question is YES, the dizzy can be repositioned to allow the wires to point away from the firewall. in either position, the clearance is tight! that is the reason for the bump on the hood.
Mike Bouse
[EMAIL="mbouse@chartermi.net"]mbouse@chartermi.net[/EMAIL]
Coldwater, Michigan USA
Home of the [B][COLOR=red]Michigan SHORTER SHIFTER[/COLOR][/B]
member, Fiat Lancia Unlimited
mbouse is offline Reply With Quote Quote
Old 09-12-2009   #3
USA
Thanks for the photo. it helps a lot. What's the best way to reposition the dist? Do I take it out and turn, say a quarter turn, to realign the the wires? I used to have a '73 850 and did not have this problem. I had pretty much 180 degrees of play on that one.
Old 09-12-2009   #4
USA
i would set the engine to TDC, then pull the dizzy off the engine, reposition the rotor shaft and the dizzy as required.
Mike Bouse
Old 25-12-2009   #5
USA
On some engines (I'm unsure of exactlty which ones) you can relocate the distributor to the other side of the engine, being driven by the auxiliary shaft.
What's that SMELL?!?
dafatrman is offline Reply With Quote Quote
Old 06-01-2010   #6
USA
i don't think that option is available after the 1438 cc engine, certainly not by the time you reach the 1755 cc engine.
Mike Bouse
(G) Distributor Drinu Uno 1 18-03-2009 00:14
(G) new distributor john waddington Panda (Classic) 2 01-05-2007 23:03
(T) Distributor Trancendental Tipo (Classic) 11 10-04-2006 22:21
(G) Distributor Peterg Uno 6 26-02-2005 12:22
(G) No distributor Auguste Panda (Classic) 16 01-02-2004 04:49
