![]() | #1 | ||
Posts: 20 Thanks: 0 Trader Rating: 0 ![]() | New Water Pump Issues I am wondering if there is anything special that you need to do when installing a new water pump to make sure that it is working properly? I just put a new pump on my (1971) 850, and I don't think that it is working. The motor gets hot (210 degrees) just driving around the neighborhood, and the heater is not kicking out any hot air when I open it up. I know that the radiator is full of fluid. I know that the belt is tight and is not slipping. I burped the air of out the system by cracking open the temperature sensing unit when the motor was hot. I am running a 160 degree thermostat, and I put it in boiling water to make sure that it opes properly. I flushed the radiator system out last fall when I put the car up for the winter. Etc... I am out of options to correct this problem short of putting on a different pump and starting over again. Any thoughts????
![]() | #2 | ||
![]() | Re: New Water Pump Issues I had a similar problem with a different car. I resulted that the aftermarket water pump that I instaled was not circulating the water so it never reached temperature in one area and boiled in another part of the engine. I would have the original water pump rebuilt and try installing it in place of the replacement that you installed. Good luck ![]() Lime Green 850
![]() | PhilWeaver | Cinquecento / Seicento | 21 | 31-12-2008 16:33 |
![]() | philmoore | Punto (Mk2/2b) | 3 | 16-10-2007 18:29 |
![]() | Tony M | Panda (Classic) | 19 | 13-04-2006 23:56 |
![]() | surfin_fella | Cinquecento / Seicento | 4 | 04-07-2005 23:56 |
![]() | jamie86 | Cinquecento / Seicento | 20 | 08-12-2004 23:17 |
