Old 12-04-2009   #1
Interference Engine in 1980 Spider
Does anyone know if a 1980 Spider (with fuel injection...not sure if that matters) has an interference or non-interference engine? I'm considering buying one that has what appears to be a badly work timing belt and trying to factor towing (if necessary) into the decision to purchase.
nospmoht1 is offline Reply With Quote Quote
Old 17-04-2009   #2
USA
Re: Interference Engine in 1980 Spider
the valves will not normally hit the pistons, but the crankshaft may kick the auxillary shaft out the side of the block. do not turn the engine until you have installed a new belt, and set the timing correctly. the auxillary shaft pulley must be set at "one o'clock"
Jay
80auto is offline Reply With Quote Quote
Old 21-07-2009   #3
USA
Quote Originally Posted by nospmoht1 View Post
does anyone know if a 1980 spider (with fuel injection...not sure if that matters) has an interference or non-interference engine? I'm considering buying one that has what appears to be a badly work timing belt and trying to factor towing (if necessary) into the decision to purchase.
definently an interference engine!
CowboyErik is offline Reply With Quote Quote
(T) 1980 spider wont start endry01 124 Spider (Classic) 3 01-09-2016 15:57
(T) 1980 Spider Alternator help shand32783 124 Spider (Classic) 2 27-05-2008 14:46
(G) 1980 Spider/2000 Radio swap-out duckie2k1 124 Spider (Classic) 3 21-03-2008 01:41
(G) 1980 Fiat Spider FI Computer ac1italiano 124 Spider (Classic) 1 21-11-2007 03:30
(T) Transmission Problems on 1980 Spider qcostello 124 Spider (Classic) 5 04-11-2004 01:12
