The unit is located under the dash, just to the right of the steering column (left hand drive cars). It is a black box with a wire going into the back. There is a round hole that is filled with a screw or bolt that has to be removed (the screw, not the hole). Once the screw has been removed, push a small screwdriver or other small tool into the hole and push until you feel a click. That will reset the counter for another 30,000 miles.
