Thread Tools
Old 23-03-2008   #1
Cigar Lighter Problems!!! Spider 2000
Looking for any advice on the cigar lighter fuse. Ive locate it and the fuse inside was a glass type tube with 5A on it. It looks fine. Manual says it should be an 8A. I tried that and its still doesn't work. Any suggestions? Deterimined to get this lighter to work.
Avorio is offline Reply With Quote Quote
Old 24-03-2008   #2
USA
Re: Cigar Lighter Problems!!! Spider 2000
Is power going to the lighter? Have you cleaned the connectors and grounds? I seem to remember that this circuit is powered at all times and not through the ignition switch. You either have a bad connection somewhere or a broken wire.
GeorgeT is offline Reply With Quote Quote
Old 25-03-2008   #3
No power to the lighter at all. Do you know what fuse is required for this?
Old 25-03-2008   #4
USA
8 Amp fuse. When you replaced the in-line fuse with an 8 amp fuse did it blow? Check to see if you have power on the circuit just before the fuse; if not you will have to trace the wire back to find the break or bad connection. I belive that it is connected to the "hot" side of the fuse block.
GT
Thread Tools
(G) Cigar Lighter Change DonSalvati Stilo 22 29-12-2007 17:55
(G) Cigar lighter for 1.1 active jgebrown Panda 4 12-08-2006 00:01
(T) Cigar Lighter Carlo Doblo 1 19-10-2004 23:17
(T) cigar lighter not working marea007 Marea 9 20-09-2004 23:40
(T) cigar lighter alfonzo Stilo 3 20-09-2004 22:32
