The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > X1/9
Old 13-12-2006   #1
852421's Avatar
Trader Rating: (0)
Australia
Electronic Ignition Conversion
Hi all,
Just joined. Bought my second X1/9 6 months ago. It's a 1980 1.5 litre Five Speed. My first one the ol' 1978 1.3 litre 4 speed is off the road many years growing ivy.
My question is has anyone converted their distributor from points to an electronic system using one of those kits available. I have not had any luck finding one.
I sent email to Pertronix and they say they don't have one for my distributor. The Marelli S135.
Any info on any available options would be greatly appreciated.
Regards
Keith
852421 is offline
Old 13-12-2006   #2
jimbro1000's Avatar
Trader Rating: (1)
Re: Electronic Ignition Conversion
Kieth,
The simplest option is to use an electronic ignition setup from a Fiat Uno with the 1300 engine. It is pretty much a straight swap but needs a bit of part mix-and-match to do the job properly as the distributor shafts are different lengths.
Next up as an alternative, I would suggest a Lumenition Optronic system if you can get one, not difficult here in the UK but I have no idea for you. This is a control module and parts to replace the points (and condenser) with an option to use a higher power coil (again from Lumenition).
The ultimate would be a complete mapped ignition system (megaspark is probably the cheapest DIY option) as this can be used to completely ditch the distributor and use a coilpack instead. If this appeals to you I would suggest getting onto the megaspark/megasquirt forums and talking to the guys on XWeb who have more than a little experience with the MS kits.
1400 turbo race X1/9 (250bhp)
1242 8v MPI 6spd Seicento (135bhp : 150bhp was undriveable)
Abarth 500 SS coming soon(ish)
jimbro1000 is offline
Old 20-12-2006   #3
852421's Avatar
Trader Rating: (0)
Australia
jimbro1000,
Thanks for the reply and the info.
I was hoping to get the Pertronix kit They do mention that they have one for the (USA?) 1974 model and that it is suited to the Marelli Distributor S153.
http://www.pertronix.com/ptx2007_cat/ptx_2007.pdf - page 6
But My distributor is a Marelli S135. Now is that a typographical error or did X1/9's have a Marelli S153 and a Marelli S135 or what?
I might have to call them I guess to make sure.
The Lumenition kit seems at least a possible option.
Regards
Keith
852421 is offline
Old 06-02-2008   #4
hrelsweg's Avatar
Trader Rating: (0)
Switzerland
Hi Keith
Finally, Have you found the pertronix electronic ignitor for the Marelli S135, and do you know what is his reference number ?
Regards
hrelsweg is offline
Old 24-03-2008   #5
Trader Rating: (0)
Hi Keith,
there seems to be a PerTronix one available (MR-145). See:
www dot vintageperformance.com/retrorockets/fiat.htm
Regards,
Dominic.
dcioccar is offline
Old 01-04-2008   #6
Jefflun's Avatar
Trader Rating: (0)
Australia
Hi
I stuck a Crane unit in my 1300 1979 X19 and it was very straight forward.
Took all of about an hour and the unit runs like a dream.
They have standard units that will fit a Marelli distributor and use existing mounting plate points screws. Timing is pretty straight forward and the instructions provided make it even easier.
Crane 700-0292 kit
Regards Jeff
Jefflun is offline
(T) no spark in electronic ignition samantha Bravo / Brava 2 26-02-2006 15:51
Electronic Ignition Thingy Sprox Panda (Classic) 39 22-02-2006 11:46
(T) Mpi engine conversion, what is involved!! JR Cinquecento / Seicento 1 08-06-2005 22:49
(G) gas conversion cinq Emm Cinquecento / Seicento 8 22-12-2004 17:47
(G) uno mk1 ignition switch wiring coolhand_mike Uno 0 06-10-2004 23:58
