The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > X1/9
Old 08-12-2006   #1
Trader Rating: (0)
X1/9 rear brakes, air leak?
My '78 X1/9 seems to be leaking air into the rear circuit. I've bleed the system a couple of times and within a few months the brakes go soggy again.
Can air leak back in through the calipers?
Pauly is offline
Old 20-01-2007   #2
Trader Rating: (0)
Re: X1/9 rear brakes, air leak?
Unlikely that it's leaking back in through the calipers themselves (the piston seals that is)
Does the system loose hydraulic fluid over time? If so, you may have an upstream leak (pipe fitting, bleed nipple etc) which weeps a little under braking, and allows air in the rest of the time.
Otherwise, you may be looking at a master cylinder. Not expensive, but a bastard to fit.
Now on my 5th X1/9. You'd think I'd have learned by now.
fastandfurryous is offline
(G) Air Box Modification polecat Marea 81 2 Weeks Ago 18:02
x1/9 brakes gemballa X1/9 3 13-11-2006 17:42
Selecta Rear Drum Brakes Tony M Panda (Classic) 53 15-10-2005 17:54
(G) Airbox on mk2 45 chrisunoman Uno 13 23-12-2004 01:15
(T) air box mod revisited jbackg Marea 1 18-08-2004 01:33
