The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > X1/9
Old 30-11-2006   #1
Trader Rating: (0)
Access to front wing to remove a radio aerial
Hi All,
A previous owner has installed a radio aerial in the nearside front wing approx 15cm from the bonnet leading edge. There's a 15mm diameter hole drilled through the top surface of the wing and the aerial was obviously installed from underneath the wing. How can I access this space to remove/replace the aerial?
Ausse X1/9 is offline
Old 01-12-2006   #2
Trader Rating: (0)
Re: Access to front wing to remove a radio aerial
Sounds like that's the area where the headlight motor is - open the bonnet and you'll see a removable flap just behind the headlight pod. If you remove this you should see the aerial in there.
Why DO people drill holes in such weird places for aerials and stuff
EXXY Central
ChrisPR is offline
Old 08-12-2006   #3
Trader Rating: (0)
Sorry for the blue, but I meant the other end of the bonnet, i.e. where it meets the windscreen.
I can't find any way into the void space from below. Can you access it from the wheel arch?
Old 11-12-2006   #4
Phil's Avatar
Trader Rating: (0)
Your right in assuming its the wheel arch area. You will have to remove the wheel arch liner, if its still fitted. Its held on by 4 or 5 tiny self tapping screws.
Phil is offline
Old 16-12-2006   #5
Trader Rating: (0)
Thanks Phil,
Old aerial is now history.
(G) How to remove front sidelight indicators Faz Punto 2 29-02-2004 19:46
(G) Front wing badges Squadrone Rosso Stilo 11 19-02-2004 03:21
(T) front wing removal fimmo Cinquecento / Seicento 2 05-02-2004 02:53
(T) Help needed - Fitting front wing JonT Bravo / Brava 2 17-01-2004 02:18
(G) How do I remove off-side wing? JonT Bravo / Brava 1 21-05-2003 00:32
