You really aren't having much luck with that car!
Cracked manifolds are pretty rare on an X1/9 thanks to the way they are mounted, the normal problem is the studs get bent where the exhaust mounts.
Don't weld them up unless you absolutely have to - it simply isn't worth it
Got bits if you need them (still)
