Hi all,
I've recently started on an x19 project '84 vs bright yellow thing.
Managed to bypass the imobilisor and got it turning over on the starter, but have found little compression on all but one cylinder.
Having started to strip the engine to down to look at the head gasket I've discovered that I can't turn the engine by hand, not even with a large breaker bar on the crankshaft pully bolt.
What do you think would be the first thing to check?
Any thoughts/discussion most welcome
Nat
Nat
