Lamps by Post - For all your lighting needs
Thread Tools
Old 16-04-2017   #1
Rear brake calipers
All,
As its Easter I've been changing the brake pads on my 1986 1500cc X1/9.
The front pair were no problem.
However both rear caliper pistons seemed stuck.
The car has done 56k miles, the front pads have been changed I assume once, about 50% wear on the existing pad. Whereas the rear look like originals, with 20% pad remaining.
I didn't disconnect the hand brake cable as the caliper came off the disk.
Would this effect the piston operation?
Replacement rear calipers seem like hens teeth, so if they are both stuck I might have a bit of a problem.
Any thoughts?
Regards,
Simon
vale of uscon is offline Reply With Quote Quote
Old 16-04-2017   #2
Re: Rear brake calipers
Hi Simon.
I'm not the best at brakes but I have read that the calipers need rebuilding sometimes.
There might be some adjustment in order to adjust the handbrake?
I doubt it would have passed an mot if they were seized?
Usually you have to wind the calipers in to allow the new pads. It's best to open the bleed nipple to do this to reduce strain on the master cylinder. Careful with the bleed nipples though as they often snap.
Worst case the calipers can be refurbished or just reassembled diy with new seals.
purf is offline Reply With Quote Quote
Old 30-04-2017   #3
Maigretnz has donated!
New Zealand
The handbrake mechanism will prevent the piston retracting. One needs to wind the piston back in.
Maigretnz is offline Reply With Quote Quote
Thread Tools
(T) Rear brake calipers bravosl165 Bravo 3 06-02-2015 21:44
(G) later rear brake calipers blackydog Barchetta 0 16-10-2014 12:52
(T) Rear Brake Calipers Kevee Bravo 13 24-12-2013 01:20
Rear brake calipers stcharlesjohn Tech Talk 5 18-07-2012 11:46
(T) rear brake calipers violanda1 Tipo (Classic) 1 04-04-2005 18:34
