Thread Tools
Old 16-03-2017   #1
1300 engine cuts in 3rd gear?
Quick post as I've not had chance to really check myself yet. Took my 1300 out for the first time yesterday for a spring shake down after Hibernation. Not been used for some time although I start it every month or so. Car starts fine etc. however on acceleration the engine cut our when I went up to 3rd gear?
Seemed fine in 1st and 2nd? I last took it around the block a couple of months ago and it was fine then so I'm guessing something stuck perhaps through lack of use? Any ideas folks?
Nello is offline Reply With Quote Quote
Old 29-03-2017   #2
Re: 1300 engine cuts in 3rd gear?
Any luck with this? I imagine the carburetor is a little dirty?
purf is offline Reply With Quote Quote
Old 08-05-2017   #3
Sorry for delay in response. Believe it or not when I checked the fuel lines running from the Carb back to the tank - One of the hoses where it met the bulkhead simply came off in my hand! No idea how the hose clip worked loose but it did! The in-line fuel filter looked a bit dirty - now I know why!
Thread Tools
(G) Engine cuts out and won't go into reverse gear either. Pagederek52 Doblo 0 09-02-2013 11:48
(T) Gear stick moving in 3rd gear ?? bravotony Grande Punto 1 11-07-2011 13:23
(G) 1978, 1300, 4 gear, shocks front & rear pls BillOliver X1/9 0 03-03-2011 07:56
(G) Help checking out 1300 4 gear Fiat X1/9 pls BillOliver X1/9 9 09-11-2008 07:11
(T) MOT Passed !!! but engine resitance in 3rd gear robinhood232 Punto (Mk2/2b) 3 20-10-2006 11:40
