FIAT Auto Specialist Team
Thread Tools
Old 07-09-2016   #1
Ireland
"Real power" engine transplant
I am seeking advice as to what engine to transplant into my x1/9. As the title hints at, I want acceleration like a missile something like the dallara replica on Youtube with the delta integrale 2wd running gear (racing 2 motorbikes and holding its own.)
Criteria:
  • Has to be easily available in Ireland, so no uno turbos, hgt or punto gts or anything Lancia
  • Has to be have less than 150bhp standard tune, fuel injected and 16 valve. Turbo preferably.
  • The lowest mass and physical dimensions preferable, as Id prefer not to cut the engine bay unnecessarily.
  • Must be as reliable as possible, I think this restrains me more to modern powerplants.
Additional info:
  • Wiring complexity not a constraint
  • Fabrication complexity of additional metalwork etc. not a constraint
  • However I want an achievable project within a reasonable time limit, proportional the the gains involved.
The third piece of additional info above rules out the bravo/marea 1.6 16v. The gain doesn't justify the effort. If Im going fabricating and wiring it has to be worth ny Time it.
So far considerations include 16V Fiat coupe engine
Fiat coupe 16v turbo
2L alfa ts
Any other suggetions? does anybody know if I will have to cut body to get the 16v in?
dallara is offline Reply With Quote Quote
Old 01-11-2016   #2
Breeze2
Breeze2's Avatar
Breeze2 has donated!
Canada
Re: "Real power" engine transplant
I'm building a full on Dallara replica.
I too need a power source to select and have the same criteria. I'm leaning towards motorcycle... but I'm a few years off from making a decision. I would sure like to know what you select.
BTW.. the shell which I have gutted and is now going through the process of roll cage, fuel cell, and brake and clutch modifications. I will be building my own wiring harness. The shell weighs nothing (only thing is the body without doors)... so bike power may be my answer.. I don't know?
Good Luck, I would love to see pictures!
Breeze2 is offline Reply With Quote Quote
Old 04-11-2016   #3
I think you can put the stilo 1.6 16v head on the original block, or a slightly more modern tipo block. Run it with aftermarket ecu and you will be over 100hp easily. This means original engine mounts can be used. No cutting engine bay and you can go turbo using factory parts from punto gt/uno like manifolds etc.
Other approach is to use fuel injection and aftermarket ecu on original engine. They are tough and can be competitive like the x19s on the UK hillclimb scene.
Have you seen the Midwest Bayless Toyota k20 conversions?
purf is offline Reply With Quote Quote
Old 06-11-2016   #4
They fail on the +1.6L bracket but what about the Alfa Twins Sparks?
Or a balls out bike engine. Waaaaa......
DaveMcT is offline Reply With Quote Quote
Old 07-11-2016   #5
Iv not seen an alfa twin spark conversion but there is an alfa V6 out there. just a few mods to get that in
Old 4 Days Ago   #6
USA
Midwest-Bayless has a conversion kit to place a Honda K20A2 plus the Honda 6 speed w/limited slip into the X1/9.
Kit is not cheap ($3700 US), and here in Florida, the K20A2 + ECU + Transmission is available for around $3000.
But, end up with 210+ hp compared to 85hp for the stock 1500FI.
Sure, the end result is a mutation, but a mutation of the fastest kind. And, definitely reliable (It's A Honda!).
I can't post the URL yet for Midwest-Bayless, but it has Midwest-Bayless in the middle.
Skillmaker is offline Reply With Quote Quote
Thread Tools
(T) "engine failure" warning & lack of power RichDoblo120 Doblo 49 22-06-2015 17:49
(T) AMS and the "Fiat Bravo Brake Scandal": the REAL lowdown skullone Bravo 24 18-04-2014 21:33
(T) Fiat Stilo 1.2 Electronic FaultThe engine have this "hiccups", then the "city" functi BladeRunner2019 Stilo 11 02-03-2011 20:04
Which one of these "real" sports do you follow Stuartl Leisure Lounge 16 24-09-2006 06:47
