Technical Clutch Pedal Not returning
PCBMBE179
I have a Bertone 1500 X19, 42000 miles. Clutch pedal will not return automatically after it is depressed. When I pull clutch pedal up and select any gear (engine running!) the gears do not engage,
I have checked fluid level in reservoir in front boot - no sign of loss of fluid.
Prior to this incident I have had no indication of clutch slip, gear difficulty etc.
What is the probable cause, please?
Next to the clutch master cylinder. Above the pedal. It's quite big about 4 inches long, half inch diameter.
