Hi Jimbro, need your advice please.
To cut a long story short, My 89 GF (13k miles from new)has blown the head gasket 3 times in the last 2 years. The first 2 times I had the head skimmed but it happened again which pointed towards a damaged block. Upon removing and stripping down the engine it was confirmed that the block was slightly damaged at the point where the gasket kept blowing and I have had the block skimmed. There is also slight water damage to the 2 bores where the leak occurred so I am having it re bored to install first oversize pistons (from 86.4/standard to 86.8/.4 oversize). I have been trying to source oversize pistons and I was steered towards Vicks Auto in the States who sell them for $199 inc the rings. They are described as 'Highest quality cast pistons available/Specs-OE [not sure who makes them though]). I spoke to a friend tonight who is ferrari trained and has his own specialist workshop and he informed me that I should not even consider cast pistons but should fit forged instead, especially as I am also having the head gas flowed..it's also fitted with a 4-1 CSC exhaust, Lumenition, K&N etc..He said that cast pistons would eventually break up if the car was driven hard over a period of time. My questions to you are 1/ I presume that original spec engines have cast pistons. Is that correct? 2/ As a non expert I don't know whose advice to take. The forged pistons will cost about 4 times as much, which isn't a problem, but is it neccesary?. I obviously want to have the job done properly to avoid having to strip the engine ever again! Incidentally, apparently the problem was originally caused by a jet being blocked by debris (the idle jet?) which caused the engine to run lean and hot-the first time it blew was after a 3hour 90mph run from Calais to Paris-by the time I got to Paris there was virtually no water left in the cooling system but it failed to register on the temp gauge until I stopped at a toll and the temp needle shot up into the red.
Your advice on this and which direction I should take would be much appreciated..Thanks
