Yeah ebay, owners club, classifieds on here... People have these things stashed away... you might consider Alfa leather seats but then they wouldn't be original ?. Would prob need modified base plate or something. I know the Alfa 147/156 seats bolt into mk2 fiat puntos ?
You could always keep the originals on the loft...
The 'wouldnt be original' comment was a bit of as joke i guess. It's good to be a custodian of these cars but likewise they need to be enjoyed and if that means modifying then so be it. My car has a few choice mods as you know.
Well first break down last night, fuel pump packed it in ? So that needs addressing...
Its still really good though, quite different to drive - actually find the Fiesta tricky now! Handling there is no comparison - RWD is a wonderful thing
I think they all do it tbh. Most cars have lost the exhaust heat shield (rusted away... ) if you can find one off a tipo/tempra possibly punto sorting or cabrio 1.6? etc this would be worth fitting too.
Doesn't it have a return line? They did originally.
The injection engine iv got has electric fuel pump ribbing constantly using factory return line and a heat shield on the manifold and its never had a fuel heat soak problem.
I guess its due to the carbs storing the fuel In the float bowls getting nice and hot right above the exhaust.
It was the fuel line rubbing against the expansion tank. As Im running twin 40s, they can't have a fuel return system. Already have the electric pump to feed the carbs so I've re-routued the fuel line and insulated it. Just need to see if it works now!
There is one on Ebay in USA, I guess it wouldn't be too difficult making one out of aluminium. Most modern cars have alloy heat shields over the manifolds.
It shares the same engine block but has a 16V head and different manifold so it will need a lot of modification.
Other than emailing people breaking 1.6 Mk1 Puntos you will probably be best off making one. If the heat shield on my car was removed I'd make a copy or a wooden buck. I tell you that would probably be lucrative - the number of X1/9s with no heat shields out there!
