Yeah easy to just swap the cam housings. Valve clearances can be checked easily while your at it. Is your cam really worn out or just surface rust?
I like the blue rocker cover now. Keep it ?
I wonder if the selector fork is In the wrong place? There might be an inspection cover which might allow you to sort it out. Otherwise is the gear selector mechanism assembled correctly underneath?
Nice carb set up. Is there space to have the trumpets offset somehow to save altering the body? I guess not.
Are you going to paint that poor core plug to protect it?
