Im just finishing fitting a 1.6 i.e tempra engine mated to an x1/9 gearbox to my 85 vs. It has bosch motronic injection and ecu with lambda sensor. My gearbox was faulty and clutch had gone. Found this engine and gearbox at a good price and went for it. Clutch is lovely and light but...
I'm now totally stuck. I have spark, fuel pump 'priming' but the injector is not squirting any fuel so it wont start.
The engine loom is fitted. I am only left with, air con connector from ecu, fuel vapor cut off switch which I have 'bridged' and one connector which joined the tempras internal loom. This is 3 wires. Going by the diagram one of these is a fuse for the lambda but I think this is wrong, one just says internal connection and one I can't recall but doesnt show one the circuit diagram.
From what I understand the 93 tempra didn't have an inertia fuel cut off but some other switch which connects 12v to the ecu. The porter manual calls it an inertia switch on one page and a fuel vapor cut off solenoid on the other (wiring diagram)
Could I have a faulty injector?
Any ideas appreciated
