So I finally decided to add a relay to my headlamps.
Got a FIAT relay holder from the local dealer and started disassembling the fuse box, only to grind to a halt almost immediately: removed the multiple connector from the back of the fuse box, located the wire that feeds the headlamps... And cannot remove the terminal from the plastic holder no matter what.
Anyone has experience removing terminals? This one looks like a standard faston 630, but I cannot find the tab that should be holding it in place.
