You guys really helped last summer with an my X1/9 overheating problem. Got it fixed and a new set of tires -- and all was well when I put it in my neighbor's garage for the winter. About a month ago it was driven from their garage to my shed and parked.
Yesterday I went to drive it, and the clutch peddle seemed from memory to go too far down. Then I discovered the clutch was still engaged. I assumed it was low fluid, but not the case. The little tank seemed to be full. There were no leaks in car under the Master or under the Slave on the concrete floor.
Today my wife watched the Salve as I pushed the peddle -- and she said it was moving.
Neither she nor I know how much it should move. So it could still be a hydraulic problem. Or, worse, something has gone wrong in the clutch.
What I just can't figure out how either problem could happen in a month sitting inside on a level concrete floor. (Unless it was happening very slowly in the garage during a very long and cold winter. But, I can't see how that could hurt clutch fluid or the clutch itself.)
Before having it towed, does anyone have any way to figure out which problem it could be?
And, if it is hydraulic -- let's say some kind of air bubbles -- how could that happen and how would I find-out and what could be done?
Thank you.
Steve
Thank you.
Steve
