Sealings are standard Uno brake cylinder, so you should be able to find them easily. The slave is an aluminium outer with a steel plunger, the master is steel outer with aluminium plunger. The slave will corrode badly and probably has to be replaced. My master was good enough to replace the sealings, but I dropped the plunger and dented it, therefore concluding it was soft aluminium.
