thank you for your reply, I have a problem with the clutch. when i bought the car the clutch was at max adjust and the gearbox was noisey. i removed the gearbox to be overhauled. the clutch plate linings had almost no wear but the damper springs were all broken. I bought a new clutch kit, ie pressure plate, clutch plate and bearings and had the flywheel machined as there were a few hot spots visable, we only took off a few thou. the gearbox was fitted but the is still at max adjust at the slave cylinder. I have replaced the clutch master cylinder and slave cyinder and it is properly bled. it seemed as if the fork wasnt being pushed far enough to disengage the clutch, there is no problem with the fork (bolt not broken or weld broken.). I have measured the slave cylinder push rod movement and master cylinder movement and it is within specs. (28mm). It just seems like the fork needs to move another 10mm to disenge the clutch and i cant seem to work out why.the workshop manual says not to machine the flywheel so i wondered why it shouldnt be machined. any help with this would be much appreciated.
