The car I have is a 1500, with CSC exhaust, stock carb (not been rejetted), brown wire mod and Lumenition electronic ignition.
Today was the first time I have test ridden the car with the electronic ignition fitted. The car started well then about two miles down the road as I went to pull away it stalled. The car wouldn't fire however the engine was spinning over as it should. I had to call the recovery out however the recovery man said that there was a spark even though it looked weak but possibly no fuel going into the carb as well. Eventually the car started under it's own accord and the recovery man hadn't done anything so he couldn't explain why it had started. This was probably about an hour after I initially broke down. I then decided to drive the car back home (about 2 miles away) and noticed the car did sound like it was lumpy under load going uphill. Once back home and the car was turned off so I could put it in the garage. When I went to restart the car it wouldn't start again. I left the car again for sometime and the car started again really easily however it did seem to start after I had released the ignition key. In the past the car has broken down before and the recovery man said there was dirt in the carb. Since this time the carb has had a rebuild. Can anyone offer any advice as I'm not sure it's ignition or fuel related and I'm nervous about driving the car? Can't understand why it just stops running intermittently.
