Just started work on my 1985 x1/9 and needed to get the front wings off and after reading a post on Xweb thought it sounds easy the post said there were spot welds on the bottom near the door post spot welds at the front to the valance and then mostly glued, POPPY CXXK there must of been about thirty weld across the top of the wing that were almost impossible to see unless your at the perfect angle then you need to drill at an angle right pain in the ass.
Am I being daft is there really an easier way! I think i'm attacking it with an angle grinder for the other side across the channel then weld in some new steel.
