shaun
Established member
Hi, i have just changed the cam belt on my 1500 and now the car turns over ok and the marks are in the right place on the cam and crank (cannot see one on the flywheel) but there is no fuel.I have removed the pipes from the pump and cranked the engine over but no fuel is coming out.The car did run out of fuel before i changed the belt or i thought it had so i have but about 5 litres in.I have read in a previous post that if the timing is out then the pump would not work is this right ?.When i checked the belt before removing it was set to about 15 degrees, now i have set it to 5 could this be the problem
Thanks Shaun
Thanks Shaun
